socalocguy4270's avatar
Mar 10, 2018
How to setup ipv6 orbi rbr50 spectrum 400 mbps
How do I configure my orbi to use ipv6, per spectrum, my modem supports it.
  • FURRYe38's avatar
    Does the ISP provide native IPv6 thru the modem?
    YOu can enable IPv6 on the router. You might ask the ISP which IPv6 configuration is needed. DHCP or otherwise.
    • guzzijason's avatar
      guzzijason
      Apprentice
      I'm not a Spectrum user, but they are most likely using DHCP6. If you're not getting an IPv6 address with the Orbi set to "auto detect" WAN network type in the IPv6 settings, then try explicitly setting the type to DHCP.
      When it comes to the LAN settings for IPv6, however, it is best to simply use "Auto Config".
      • RocketSquirrel's avatar
        RocketSquirrel
        Luminary
        I found I had to change IPv6 Filtering from Secured to Open in order to get IPv6 to work at all. Set to Secured, v6 failed 100% of the time. I wonder how big a security hold I've opened.
