Stev3D
Dec 27, 2017Luminary
How to specify VPN connect to the primary (not guest) network
I set up VPN so I can remotely access resources on my primary network. I discovered (the hard way) that, by default, the VPN tunnel attaches to my guest network -- which doesn't do me any good. Is there a way to tell the Orbi to make the connection to the primary (not guest) network?
Thank you.
1 Reply
- Stev3DLuminary
Really surprised that nobody responded to this one -- but I posted it during a peroid of "down time" for many. If you know anything about VPN on a Netgear device, please take a look. Thank you.
