msfox99
May 19, 2017Guide
How to tell signal strength between router and satellite? (other than lights)
Hi, besides looking at the color of the light on the top of the Orbi, is there something in the web admin app which will show me how strong the signal is between the router and the satellite? I am g...
OrbiMan
May 19, 2017Luminary
There is a convoluted way. You can connect a laptop to each Orbi via ethernet then run iperf3 between those two computers that will let you know the speed of the backhaul which is equate to signal strength.
