BhamMOM's avatar
BhamMOM
How to turn off parental controls
Hi,
I updated the firmware for my Orbi and somehow it turned on parental controls.  I already have a standalone circle device so I don't need the built in ones in the Orbi.  I cannot login to my orbi via orbilogin.com on my  brower to make some adjustments to the orbi because the Orbi parental controls are blocking my access.  Please someone help me figure out how to disable this.  I know its not my stand alone circle because I have this device unmanaged.
  • CrimpOn's avatar
    CrimpOn
    Rather than use "orbilogin.com" in the web browser, can you use the actual IP address of the Orbi?  If should be the same as the "gateway IP address" reported in network settings.  i.e. http://192.168.1.1
    Do you use the Orbi "app" to manage the Orbi?  If so, Parental Controls should be one of the options.  (If you have not used the Orbi app, I would not recommend installing it, rather....)
    A sure fire, guaranteed method to disable Parental Controls is to Factory Reset the Orbi and perform a new setup.
    https://www.youtube.com/watch?v=cMw4ePACgc4
    During the new setup, I would be borderline paranoid about not clicking on anything that might activate Circle again.  As I recall, Netgear is almost insistent on customers activating Armor and Circle and it takes a bit persistance to avoid doing so.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the Orbi system been performed since last update?
    BhamMOM wrote:
    Hi,
