Steve_Zhang
Sep 24, 2017Initiate
How to use daisy chain topology on Orbi Satellite ?
I have a Orbi router (RBR50) and two satellites (RBS50). When I upgrade firmware to V2.0.0.74 , I found Orbi supports daisy chain topglogy (Advanced-Advanced Setup-Wireless Settings-Backhaul Topolog...
- Sep 25, 2017
You can't control what connects to what. With daisy-chain, if a satellite sees a signal from another satellite is stronger than the router's signal, it will chain through the satellite instead. There is no way to explicitly connect two satellites.
Rodney
rhester72
Sep 25, 2017Virtuoso
Rodney
JeffParker
Oct 22, 2017Tutor
Is daisy chaining preferred? Not sure if this is causing an issue that I'm having: one of my latops seems is dropping vpn connection every fe mins and then reconnects. This only seems to happen when it's connected to 2.4ghz nw
rhester72 wrote:You can't control what connects to what. With daisy-chain, if a satellite sees a signal from another satellite is stronger than the router's signal, it will chain through the satellite instead. There is no way to explicitly connect two satellites.
Rodney
