Steve_Zhang
Sep 24, 2017Initiate
How to use daisy chain topology on Orbi Satellite ?
I have a Orbi router (RBR50) and two satellites (RBS50). When I upgrade firmware to V2.0.0.74 , I found Orbi supports daisy chain topglogy (Advanced-Advanced Setup-Wireless Settings-Backhaul Topolog...
- Sep 25, 2017
You can't control what connects to what. With daisy-chain, if a satellite sees a signal from another satellite is stronger than the router's signal, it will chain through the satellite instead. There is no way to explicitly connect two satellites.
Rodney
rhester72
Sep 25, 2017Virtuoso
Rodney
Steve_Zhang
Nov 01, 2017Initiate
Thank you very much. Follow your tips,I have succeeded.
Steve
