ADAM01234
Sep 30, 2017Follower
HP printer won't recognize router
Orbi not appearing in HP MFP 377 list of availble wireless networks. SSID isn't showing up and doesn't work when set up manually. New printer, initially it didn't recognise the Orbi wifi and after r...
Mikey94025
Oct 02, 2017Hero
My HP M477fdw works fine with my Orbi. What wireless security option are you using? Have you made any changes to the Orbi Advanced Setup wireless settings, transmit power, etc.?
Note that the HP printers will only work on the 2.4Ghz wireless network, not 5.0Ghz.
- aazOct 02, 2017Virtuoso
Also you may want to ensure that you don't have any weird characters in your SSID - no spaces or anything other than letters and numbers, and limit the length of the name.
