Hectorj
Dec 02, 2018Tutor
I can’t seem to be able to upgrade my orbi firmware from 1.2.0.6 to the latest version manually
I’m trying to upgrade my orbi manually and automatically from 1.2.0.6. It doesn’t detect new firmware automatically. When I try the manual approach it says the firmware version is not compatible even ...
- Dec 02, 2018
After upgrading to an intermidiate firmware (1.11.0. 20) from 1.2.0.6, I was able to install the latest 2.2.1.210
Thanks!
st_shaw
Dec 02, 2018Master
Pay close attention to the firmware files you are uploading to the router and satellites. There are two files. There is one file for the router "RBR50" and a different file for the satellites "RBS50". There is no firmware file for an RBK53.
If that's not your problem, you might need to upload intermediate versions of the software because version 1.2.0.6 is very old. You might need to load 1.3, 1.4, or 1.5, etc. first.
Hectorj
Dec 02, 2018Tutor
Yes, I was aware there are 2 files: 1 for the router and 1 for the satellites. I'll try the intermediate updates and see what happens later
- HectorjDec 02, 2018Tutor
Thanks!
- st_shawDec 03, 2018Master
Good! Thanks for letting us know it worked.
- DickDukeDec 04, 2018Apprentice
st_shaw, The solution is great for those of us with some technical facility, but may be a bit too complicated for many of the home users in the target market.
i wonder if the wizards at Netgear could script this two step solution into something that the auto update feature could perform?
