Slink131's avatar
Slink131
Follower
Feb 01, 2018
I can't connect to the satellite Orbi RBS50
One of my satellite disconnected and will not connect. It will either stay purple or color goes away and still does not connect. I moved it right next to my router and it still won’t connect. The other satellite is connected
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Did you try to factory reset the unit?
    DarrenM
