gabier2
Apr 09, 2018Guide
I get mad with password problems
Hello everybody, Relying on past experience with Netgear products, I expected a quick installation of my brand new Orbi system. The start up of the router and satellite and their appairing worked q...
- Apr 10, 2018
Yes do a factory reset on the router and use firefox browser and navigate to 192.168.1.1 and the set up wizard will be waiting for you. Walk thru this wizard. Thats all that needed.
gabier2 wrote:FURRYe38 wrote:
Factory reset the Orbi router and connect a wired PC to the router and walk thru the setup wizard.
What is the Mfr and model# of the ISP modem?
OK, I will do this, but what is the "setup wizard" ? How do I execute it ? Does it come automatically after the factory reset ?
The Mfr is "Sagemcom Broadband SAS" (a french Mfr), it is let by my ISP (ORANGE) with the name "LiveBox 4"
dokG
Apr 09, 2018Aspirant
I have the same problem with the admin password access. The app was humming along fine for the past six months and then it asked me to provide the password login. I used the default password that came with the system and that has been used since I received the system, but it locks me out. When I go online to change it, it asks me security questions that I have never answered.
I rebooted the system, but no luck there. Do I have to do a new set up (I hope not as the first time around was painful).
Thanks.
Apr 09, 2018Guru - Experienced User
Walk thru the setup wizard and input a new PW for the admin account. This is one of the requirements during this process.
dokG wrote:I have the same problem with the admin password access. The app was humming along fine for the past six months and then it asked me to provide the password login. I used the default password that came with the system and that has been used since I received the system, but it locks me out. When I go online to change it, it asks me security questions that I have never answered.
Thanks.
- dokGApr 10, 2018Aspirant
Thanks. I did end up resetting and re-registering via Google Chrome. All seems to be functioning with the exception of the app able to do an Internet speedtest. I will consider Firefox if I have to do this next time.
- FURRYe38Apr 10, 2018Guru - Experienced User
Seems the the mobile app is having problems:
Use speedtest.net app on android or iphone as a alternative speed test app.
dokG wrote:Thanks. I did end up resetting and re-registering via Google Chrome. All seems to be functioning with the exception of the app able to do an Internet speedtest. I will consider Firefox if I have to do this next time.
