Hsc1102's avatar
Hsc1102
Apprentice
Nov 04, 2019
I Give Up, Returned the RBK53
That’s it. After years of connection issues and promises of improvement with firmware upgrades only to be left waiting for another firmware upgrade to fix the previous issues , I decided to return the RBK53. Thank goodness for Costco and their generous return policy!!!
Any recommendations?
  • CrimpOn's avatar
    CrimpOn
    Of course.  Google for "Best WiFi System", then check out the user forums for the leading products.  People seem to rate Linksys Velop, Google WiFi, TP-Link Deco (M5 and M9), and several others.  People on this forum own Netgear Orbi and are well acquainted with its strengths and weaknesses.  People who own the other products may be in a similar position.
    Good Luck
  • Retired_Member's avatar
    Retired_Member
    That's too bad.  If you return it due to firmware issues, I believe you'll all the others face the same problem.  They key is stay away from manual updates.  If your system is working, why upgrade the firmware?
    • Hsc1102's avatar
      Hsc1102
      Apprentice
      I've been on some 'fairly stable' firmware versions before, but netgear just never seems to get it right.  This day and age with the complexity of technology all companies experience issues with a version of their firmware, but it just seems like netgear was never able to get it right.  One version, I would have continuous connectiveity at slower than expected speeds and other versions I would have fast speeds but it would constantly disconnect especially when I am on a conference call for work.  This is not what you expect for a ~$400 system that promises fast speeds and big range.  Seems like firmware limited the ORBI's potential.
        Retired_Member
        How was your firmware installed?
  • plemans's avatar
    I've used multiple mesh networks. I'll rank them from my experience. Again, this is just my experience, it isn't scientific.
    Here's how I'd rank what I've used.
    1. Orbi RBK53
    2. Arris W31
    3. Orbi RBK43
    4. TP-Link M9plus
    5. Tenda MW6
    This are the systems I've used so I can't speak to how the other wifi mesh systems work or reliablity. I will say that they've all had issues. None have been perfect.
    Smallnetbuilder does reviews and ranks systems. there's great reviews there and its worth looking/reading through it a bit before buying your next system.
    https://www.smallnetbuilder.com/tools/rankers/wifi-system/view
  • If you have any technical knowledge throw in some Ubiquiti AC Pro access points. They’re low end enterprise but high end consumer.
