Spotteddog444's avatar
Jun 27, 2018
I have a new Orbi "50", how can i connect my old "40" satellites?
  • FURRYe38's avatar
    Should work. Speeds will differ between the 40 series and 50 series though.
  • FURRYe38's avatar
    What 40 series satellites do you have? RBS##?
    Are you able to add the satellites using the Sync button on the router and satellite?
    DarrenM
    • Spotteddog444's avatar
      Spotteddog444
      RBS40, I've tried the sync button. They flash white, then solid magenta
  • FURRYe38's avatar
    What versions of FW are loaded on the 40 and 50 series units? Should all be the same version...
