Drj37's avatar
Drj37
I have Cox ultimate 300 down 34 up
So my download speed is always over 300 but now my upload is around 8-10 any help it started doing it on my last orbi so I figured it was the orbi took it back to Bestbuy exchanged it out for another orbi and I get the same thing cox has been out 3 times and said nothing is wrong
    • Drj37's avatar
      Drj37
      I have the Netgear cm1000 as my modem
    • Drj37's avatar
      Drj37
      I’m wondering if I should try a factory reset and see if that has anything to do with it
  • FURRYe38's avatar
    If you have upgrade FW to beta, yes, please try the reset and set up from scratch. I would avoid setting up QoS, Traffic Meter or Access Controls.
    Try a reset then do a speed test with a ethernet connected PC. Should be getting to spec speeds...
    Just making sure the ISP modem doesn't have a built in router is all.
