SLK-Purdue's avatar
SLK-Purdue
Luminary
Jul 31, 2021
I object in the strongest possible terms (ref new firmware auto update and removing TELNET option)
I want to object in the strongest possible terms to NG updating my Orbi firmware overnight even though I had set the parameters for no auto-update.
Additionally, now that I have new firmware (v2.7.3.22), the "Enable TELNET" option has been removed!!!
I am sitting here with a new version that I didn't want and no way to control it via nvram parameters.  WTF Netgear?   The power of this equipment is the reason I bought it.  I get that Telnet can be dangerous for people without exerience but it also is the power of quality equipment for trained professionals.  Why remove a valuable feature?
I am heading back to older firmware and I don't want an auto-update if the new version doesn't have features I want.   How to I ensure that?
Scott
Scott
  • Hi there,
    Facing the same issue, I could restore telnet access using the updated version of telnet-enable2.py, enabling back Telnet using V2.7.3.22: https://github.com/bkerler/netgear_telnet
    I could push all my existing custom configuration (upnpc, automation, etc.) from here.
    Hope this will help you as well...
    • CrimpOn's avatar
      CrimpOn
      My goodness gracious.  This works on my RBR50 with firmware v2.7.3.22!
      I have tried the python script on Linux.
      Will try it on Windows and also the compiled versions.
      Thank you. Thank you. Thank you.
