Delphimon
Mar 16, 2020Follower
If you are having "dropouts" with 2.5.1.8 firmware please read
I recently upgraded to firmware 2.5.1.8 to attempt to fix another problem I was having, but ever since I've noticed that the router seems to lose it's connection multiple times per day. As one other ...
PeteWalker74
Mar 17, 2020Aspirant
Thanks so much for posting this. I'll keep an eye on this, and will try the "test" if I get a WIFI drop and see if it fixes it.
Before I read this, I went to look at previous versions, but when I went to download, it gave me a 404.
Question: Has anyone who has had the WIFI disconnect issue described here successfully downgraded the firmware and confirmed that fixes the issue?
If so, does anyone have working links for the previous RBR50 and RBS50 (gen 1) firmware handy?
Thank you all very much.
Mar 17, 2020Guru - Experienced User
Factory reset your RBS and RBR and setup from scratch to see if this fixes your problem before downgrading.
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
IF the reset or suggestions to try doesn't help, then go here:
https://www.netgear.com/support/product/RBK50.aspx
PeteWalker74 wrote:Thanks so much for posting this. I'll keep an eye on this, and will try the "test" if I get a WIFI drop and see if it fixes it.
