Delphimon
Mar 16, 2020Follower
If you are having "dropouts" with 2.5.1.8 firmware please read
I recently upgraded to firmware 2.5.1.8 to attempt to fix another problem I was having, but ever since I've noticed that the router seems to lose it's connection multiple times per day. As one other ...
apt-get
Apr 27, 2020Aspirant
So I experienced this today and whilst pinging 1.1.1.1 did NOT work, using 192.168.1.1 to get to the router admin page then and 'testing' the internet did indeed restore connectivity. I'm going to raise with Netgear.
- apt-getApr 27, 2020Aspirant
....another drop out, again fixed by the 'test internet' button...
- Retired_MemberApr 27, 2020
apt-get wrote:....another drop out, again fixed by the 'test internet' button...
I doubt it's fixed with 2.5.1.8
- FURRYe38Apr 27, 2020Guru - Experienced User
What is the mfr and model# of the ISP modem/ONT that the Orbi router is connected too?
Swap LAN cables between the modem/ONT and Orbi RBR. CAT6 is recommended.
I would update to v16, factory reset and setup from scratch.
It's a Huawei Echolite I believe. If I update to that version and factory reset, can I restore from a config backup or literally have to go through the full setup again?
