Delphimon
Mar 16, 2020Follower
If you are having "dropouts" with 2.5.1.8 firmware please read
I recently upgraded to firmware 2.5.1.8 to attempt to fix another problem I was having, but ever since I've noticed that the router seems to lose it's connection multiple times per day. As one other ...
apt-get
Apr 27, 2020Aspirant
So I experienced this today and whilst pinging 1.1.1.1 did NOT work, using 192.168.1.1 to get to the router admin page then and 'testing' the internet did indeed restore connectivity. I'm going to raise with Netgear.
apt-get
....another drop out, again fixed by the 'test internet' button...
- Retired_MemberApr 27, 2020
apt-get wrote:....another drop out, again fixed by the 'test internet' button...
I doubt it's fixed with 2.5.1.8
- FURRYe38Apr 27, 2020Guru - Experienced User
What is the mfr and model# of the ISP modem/ONT that the Orbi router is connected too?
Swap LAN cables between the modem/ONT and Orbi RBR. CAT6 is recommended.
I would update to v16, factory reset and setup from scratch.
- apt-getApr 27, 2020Aspirant
It's a Huawei Echolite I believe. If I update to that version and factory reset, can I restore from a config backup or literally have to go through the full setup again?
Does this modem have a built in router and wifi? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIt's recommended to reset and setup form scratch. See if the problem still happens. You can apply the config file and test as well after the reset. If it happens use the backup config after the reset, it would need another reset and setup from scratch with out loading the backup config file to see if the problem happens again.
