tdcarp
Aug 25, 2021Aspirant
I'm I correct that the RBK50 does not include a modem?
I going to replace a Netgear ORBI CBR40 with a couple Netgear EX6100 extenders. Although mesh is probably overkill for us, I looked at the RBK50 mesh router/extender. The CBR40 was a modem/router. Is the RBK50 just a router, meaning I'll need to get a modem? If so, is there anything to consider re: the modem selection?
I also noticed that the RBK50 was not in the pull-down list of devices for this post. It appears the closest in name is the RBR50. Is there a reason why the RBK50 isn't listed?
Sort By
- tdcarpAspirant
Sorry about the type. The Subject should be "Am I correct..."
Is the CBR40 not working for you?
Any RBR or RBK model does NOT have a built in modem and relies on connecting to a ISP service modem/ONT or other ethernet connection providing internet services.
The CBR40 can work as a modem only.
The CBR40 can still be used as a modem only or in router mode and add a RBS20 or RBS40v to it for additional coverage for better coverage and freature operation.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connectedRBK50 and RBR50 are the same series. RB(K) is the kit version which has a RB(R)50 router and and RB(S)50 satellite in the box.
