lporbiuser's avatar
lporbiuser
I'm not paying Netgear to replace their broken product
I am very very frustrated. My router is rebooting about every 15 minutes now. Netgear has offered to replace it, but they want me to pay to ship the defective unit back to them, and THEN wait 8 to 10 business for the replacement. I do not have a backup router; that is not an option.
The right thing is for Netgear to send me a replacement unit first. But they want $16.90 for this. That's outrageous. I can't believe we paid hundreds of dollars for this system that's been nothing but a headache, and now this. I hope a moderator will contact me and do the right thing.
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Most router mfrs do the same thing for shipping. How it's been for a long time now.
    Next time, ask for a cross shipping RMA. This allows them to send you a new unit, once you get it, you them them back the old unit. You have to be sure to ship the old unit back though or they will charge you for the new unit.
    • lporbiuser's avatar
      lporbiuser
      Netgear CM500V
      The size of the house is irrelevant to this issue. The router is rebooting constantly.
      I am using factory settings. That should be good enough to have a functioning product.
      They do offer cross shipping RMA. It's $16.90. That's the crux of this thread.
      • FURRYe38's avatar
        When it come to Orbi, everything is relevant. Got others working on there systems with some minor changes. it does help.
        Try the suggestoins or contact NG support on the phone. Take the cross shipping offer. Nothing else can help you here in the forums...NG offfical support on the phone will be able to help you.
