jmielke
Oct 17, 2018Aspirant
iMac won't join network
imac running mojave immediately says it can't join the network when the SSID is selected. Sometimes it asks for the password and then says it can't join the network. The machine can join other networks; just not the Orbi.
Tried: replacing pref files
changing the network name
changing secuirty
doing a factory reset on the Orbi
Same issue when the machine was running High Sierra
Other devices can connect including an older imac.
Any suggestions appreciated.
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try this as well:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only. - ekhalilMaster
In my case such "starnge" issues -I noticed- were not directly related to the device or Orbi but were caused by "loops" in my network!
Please disconnect all wired devices, restart Orbi and see if the issue will be gone. If yes, then start connecting the devices one by one to locate which device is causing the issue. If you have ethernet mesh speaker (Sonos for example) then most probably it's them causing all your troubles.
