P95357
Mar 02, 2025Guide
Impossible to install Arlo Go2 camera on Orbi RBK53
The Arlo Go2 camera needs a phone with the Arlo app connected to 2.4GHz. The RBK53 won’t let me choose the network, and the phone always connects to 5GHz. I’m not sure if there’s a way to temporarily ...
Mikey94025
Mar 03, 2025Hero
P95357 wrote:
The app then leads me to troubleshooting steps and the very first item is to ensure the phone is in a 2.4GHz band.
Your phone might still be using the 5Ghz band from your previous setup. After you hide the 5Ghz SSID in Orbi, go into your phone and Forget the SSID connection (to make sure it forgets the 5Ghz band). Then add it again (this time it can only see and use the 2.4Ghz band). Now try setting up your Arlo camera again.
CrimpOn
Mar 03, 2025Guru - Experienced User
One of the benefits of cameras is they can "see things" (unlike other devices such as smart plugs, light bulbs, garage door openers, etc.) This makes the connection process SO much easier because:
- The smartphone app can create a QR code containing the SSID/password of the WiFi connection.
- Factory Resetting the camera causes it to start looking for a QR code.
- Showing the QR code to the camera provides the information needed to for the camera to connect.
- Since the camera is looking for a WiFi connection that matches the SSID/password on the QR code, it will "see" the Orbi on whatever WiFi frequency band the camera supports. (I have cameras that contain only 2.4G WiFi radios and cameras that have both 2.4G and 5G WiFi capability.)
Would it be possible to have some other device "look at" the QR code displayed by the smartphone app so that you can see the contents? (There are several apps for Android that will do this. Obviously the smartphone cannot "look at itself", so there needs to be another device.)
