bgreimel's avatar
bgreimel
Follower
Sep 14, 2021
Improving connectivity outside main house
I have an RBR20 router and 2 satelites in my ranch home...reception is good including most of my back yard...the issue is this...I work from home a bit and want to move my office set up to an outbuilding approximately 60' from the router but it has metal siding which inhitits connectivity...should I add a satilite?
  • FURRYe38's avatar
    I recommend getting a CAT6A cable from the home out to this office building 60 feet away, then place a RBS ethernet connected at this location.
  • CrimpOn's avatar
    CrimpOn
    bgreimel wrote:
    I have an RBR20 router and 2 satelites in my ranch home...reception is good including most of my back yard...the issue is this...I work from home a bit and want to move my office set up to an outbuilding approximately 60' from the router but it has metal siding which inhibits connectivity...should I add a satilite?
    Several alternatives come to mind:
    • The #1 choice is to install an ethernet cable from the router to the outbuilding.
    • It is tempting to ask if there is a window in the outbuilding that faces the main house.  If so, a satellite placed in the window might connect to the router and also provide WiFi inside the outbuilding (as well as ethernet). Metal walls block WiFi, but much more so than windows.  However, 60' is 'pushing it' in terms of the WiFi backhaul, unless there happens to be a satellite close to the outbuilding than the router.
    • Installing ethernet cable can sometimes be impractical (building penetrations, crossing concrete, etc.). There have been numerous posts reporting success with point-to-point wireless bridges, such as the Ubiquiti NanoStation (or similar)
      https://www.amazon.com/Ubiquiti-Bundle-NanoStation-Outdoor-airMAX/dp/B01EBBKVDE/ref=sr_1_3?dchild=1&keywords=ubiquiti+nanostation&qid=1631600287&sr=8-3   With such a short distance, one of the bridge units can be located indoors. Because of the metal construction of the outbuilding, that unit may have to be located on the exterior with the ethernet cable penetrating the outbuilding wall.
