Crofty7's avatar
Crofty7
Improving my home network
Hi,   I currently own a ReadyNAS RN212 with 2 2TB discs. I dont use the NAS as a back up device, i use it more as a server. All my documents, photos and videos are stored on it. I was under the a...
  • FURRYe38's avatar
    Sounds good. Yes too close can cause problems. Sometimes you have to play around with placement. I found that 30 feet to start with is a good starting point. I have mine at 40 feet.
    Good Luck.
