Crofty7
Jan 05, 2019Aspirant
Improving my home network
Hi,
I currently own a ReadyNAS RN212 with 2 2TB discs. I dont use the NAS as a back up device, i use it more as a server. All my documents, photos and videos are stored on it. I was under the a...
- Jan 07, 2019
Sounds good. Yes too close can cause problems. Sometimes you have to play around with placement. I found that 30 feet to start with is a good starting point. I have mine at 40 feet.
Good Luck.
Jan 06, 2019Guru - Experienced User
If you have a ISP modem with a built in router:
Modem Combo Units:
Couple of options for use with a Orbi router system,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If your on cable and want to replace the ISP cable modem with a gateway modem you could get a ORbi with the built in cable modem:
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Static IPs are recommended on NAS. Set up the main host routers IP address pool for 192.168.1.100 thru .200. Then anything on either side of this pool can be used for static IP addresses that are set ON the NAS device. I do this on my NAS. The .100 thru .200 address pool is for IP address reservations ON the router for other devices.
Crofty7
Jan 06, 2019Aspirant
Hi FURRYe38,
What does Mfr mean?
This is the modem/router i have https://www.shop.bt.com/products/bt-smart-hub-088138-C6NX.html
I don't have an Orbi system yet, i'm considering purchasing one. Is there much point in purchasing an Orbi modem (CBK40) as in the UK we don't rent the modem/router. Should i just use the BT Home Hub6 or is the CBK40 much more advanced and work better with the RBK53?
My house is approximatly 2200 sq ft. It's solid blockwork constuction and i struggle for wifi signal upstairs. The sattelite units would be 20 to 30ft away from one another. Would this be an issue?
I don't know how to set up static IP addresses, is there some very simple, and i mean simple!, instructions on how to do this? Finally, and this is dependent on which modem/router i use (BT Home Hub or Orbi), should i refrain from setting up static IP addresses until i have the mesh wifi system installed?
- FURRYe38Jan 06, 2019Guru - Experienced User
Mfr = Manufacturer
That particular modem/router you have would need to be bridged or configured as such to use with a RBK## series Orbi system.
Your on a DSL or Fiber ISP service so the CBK40 system will not work for you. The CBK40 is for a Cable ISP service only.
30 feet is recommended in between them to start with depending upon building materials. I have mine at 40 feet in between.
Yes don't worry about static IPs until you finalize what your going to be using and have that installed.
- Crofty7Jan 07, 2019Aspirant
On my modem/router you can turn off wi-fi, so if i connect the orbi router with BT hub would this suffice?
Also if the Orbi satelites are closer than 30ft will this cause a problem?
- FURRYe38Jan 07, 2019Guru - Experienced User
IT would be ok, however with the modem having a built in router, this may cause other problems. I would Advise you to look at the modem combo suggestions mentioned earlier in this thread. Try Options #2 and #3.
Yes, distance should be starting at around 30 feet.
