Crofty7
Jan 05, 2019Aspirant
Improving my home network
Hi,
I currently own a ReadyNAS RN212 with 2 2TB discs. I dont use the NAS as a back up device, i use it more as a server. All my documents, photos and videos are stored on it. I was under the a...
- Jan 07, 2019
Sounds good. Yes too close can cause problems. Sometimes you have to play around with placement. I found that 30 feet to start with is a good starting point. I have mine at 40 feet.
Good Luck.
Crofty7
Jan 07, 2019Aspirant
OK thanks.
I'll speak with my ISP first and go from there. I'll also check distances as I fear the satellites may be too close.
Thanks for your help
Jan 07, 2019Guru - Experienced User
Good Luck.
