JWUC
May 17, 2018Initiate
In-line vs on a network node
Good Afternoon, We recently purchased a new house and the area where all the networking cables converge is in the master closet in a wall panel. It's not the most ideal location for the orbi as it'...
May 18, 2018Guru - Experienced User
Be sure your using a NON managed switch. There are known issues with managed switches causing problems with Orbi systems.
Always put a switch after the router.
JWUC wrote:
Good Afternoon,
We recently purchased a new house and the area where all the networking cables converge is in the master closet in a wall panel. It's not the most ideal location for the orbi as it's in the farthest corner of the house. We make use of the Disney circle a lot for the kids as well.Current setup: Modem > Orbi > 16 port switch > devices
Would there be any issues with either orbi operation or Circle if the setup was changed to
Modem > Switch > Orbi/Devices (where the orbi and the Computers are on separate ports of the switch)
- JWUCMay 18, 2018Initiate
Thanks for the relplies all.
I'll go ahead and maintain the current setup.
I was just looking to save $200 by not buying another satellite if I could move the main unit to a more optimal location.
The switch I have is unmanaged, so no issues there.
