pfgthird
Feb 24, 2018Follower
Initial setup
Just trying to install the system. I get to the last step and it keeps telling me I'm not connected to the Orbi WiFi Network. I check my computer, it says I'm connected. Over and over, same result...
Feb 24, 2018Guru - Experienced User
What is the Mfr and model of the ISP modem?
I presume yoru trying to get the Orbi router connected first? Focus on getting this conencted first to the ISP modem and services. Then set up the Satellite 2nd after the router is fully working.
Use a LAN cable wired PC to the back of the Orbi router.
Use IE11 or FF browser to walk thru the set up wizard. Disable any PC security software and browser add ons temporarily while setting up the router and Satellite.
After you walk thru the set up wizard, you might log out, empty browser caches and then reopen the browser. After setting up the router, check for internet access and run some speed tests.
Disable IPv6 if your ISP doesn't support this natively.
I've disablied Beam forming and MIMO wireless features for me and all my devices work well. Including my Satellite at the opposite end of the house from the router.
