pfgthird
Feb 24, 2018Follower
Initial setup
Just trying to install the system. I get to the last step and it keeps telling me I'm not connected to the Orbi WiFi Network. I check my computer, it says I'm connected. Over and over, same result...
webminster
Feb 24, 2018Luminary
Are you using the app (Orbi app or Genie) to setup? You say stuff is connected, are you getting Internet access etc? Can you get to the Orbi via browser (orbilogin.com)? Few more details would be helpful.
