Marcptk's avatar
Marcptk
Initial setup
trying to get initial router RBR20 setup. I have connected router to my xfinity modem via an ethernet cable. Setup validates that router is connected to modem but says no internet connection which is...
  • michaelkenward's avatar
    michaelkenward
    Sep 07, 2018
    That's good.
    Why not make life easier for anyone who arrives with the same problem?
    Tell them where you found the answer and mark your own problem as solve.
