Marcptk
Sep 06, 2018Aspirant
Initial setup
trying to get initial router RBR20 setup. I have connected router to my xfinity modem via an ethernet cable. Setup validates that router is connected to modem but says no internet connection which is...
- Sep 07, 2018
That's good.
Why not make life easier for anyone who arrives with the same problem?
Tell them where you found the answer and mark your own problem as solve.
Marcptk
Sep 07, 2018Aspirant
All set. I found a trouble shooting wizard from a similar post on this site which configured the router properly. All seems to be worked my now.
michaelkenward
Sep 07, 2018Guru - Experienced User
That's good.
