robaz
Mar 04, 2018Aspirant
Install Orbi via VPN Router
I live in an apartment and have a modem. Plugged into that modem I have a VPN router, I live in China. I wanted to hook the Orbi to the end of that. I currently have a Tenda Nova (cheapo version of a...
Mar 04, 2018Guru - Experienced User
Did you try using AP mode with the Orbi router behind the VPN router?
Whats the IP address pool that the VPN uses? 192.168.1.#?
robazwrote:I live in an apartment and have a modem. Plugged into that modem I have a VPN router, I live in China. I wanted to hook the Orbi to the end of that. I currently have a Tenda Nova (cheapo version of an Orbi and it works fine. Obbi doesnt get a signal. Do I need to scrap the VPN router and hook directley into the Modem. If I do can I put a VPN on the Orbi?
- robazMar 04, 2018Aspirant
No I havent tried AP mode but will. Can I still get in and configure the Orbi even though it isnt technically on the network?
- FURRYe38Mar 04, 2018Guru - Experienced User
Yes you can walk the set up wizard and skip any set up steps for the internet with a Ethernet cable connected PC.
Starting to get above my pay grade. I bought the system assuing it would be pretty simple. I have a Tenda Nova now and it set up effortlessly behind the VPN router. Clearly the Orbi is another thing all together. Am going to try connecting directlyto my modem and going back to turning on a VPN on all devices. A pain but easier I think.
