robaz
Mar 04, 2018Aspirant
Install Orbi via VPN Router
I live in an apartment and have a modem. Plugged into that modem I have a VPN router, I live in China. I wanted to hook the Orbi to the end of that. I currently have a Tenda Nova (cheapo version of a...
robaz
No I havent tried AP mode but will. Can I still get in and configure the Orbi even though it isnt technically on the network?
Mar 04, 2018Guru - Experienced User
Yes you can walk the set up wizard and skip any set up steps for the internet with a Ethernet cable connected PC.
- robazMar 04, 2018Aspirant
Starting to get above my pay grade. I bought the system assuing it would be pretty simple. I have a Tenda Nova now and it set up effortlessly behind the VPN router. Clearly the Orbi is another thing all together. Am going to try connecting directlyto my modem and going back to turning on a VPN on all devices. A pain but easier I think.
- FURRYe38Mar 04, 2018Guru - Experienced User
Yes the Orbi has it's own router so if you have another already in front, then could be a problem.
Hope the Modem is a modem only. Modem only is preferred.
Let us know how it goes.
robazwrote:Starting to get above my pay grade. I bought the system assuing it would be pretty simple. I have a Tenda Nova now and it set up effortlessly behind the VPN router. Clearly the Orbi is another thing all together. Am going to try connecting directlyto my modem and going back to turning on a VPN on all devices. A pain but easier I think.
Modem is modem only. Varies lan cables lead to access points in other rooms. Do you know if I can configure a VPM (exprees, astrill etc) directly onto the Orbi?
