robaz
Mar 04, 2018Aspirant
Install Orbi via VPN Router
I live in an apartment and have a modem. Plugged into that modem I have a VPN router, I live in China. I wanted to hook the Orbi to the end of that. I currently have a Tenda Nova (cheapo version of a...
robaz
Starting to get above my pay grade. I bought the system assuing it would be pretty simple. I have a Tenda Nova now and it set up effortlessly behind the VPN router. Clearly the Orbi is another thing all together. Am going to try connecting directlyto my modem and going back to turning on a VPN on all devices. A pain but easier I think.
Mar 04, 2018Guru - Experienced User
Yes the Orbi has it's own router so if you have another already in front, then could be a problem.
Hope the Modem is a modem only. Modem only is preferred.
Let us know how it goes.
robazwrote:Starting to get above my pay grade. I bought the system assuing it would be pretty simple. I have a Tenda Nova now and it set up effortlessly behind the VPN router. Clearly the Orbi is another thing all together. Am going to try connecting directlyto my modem and going back to turning on a VPN on all devices. A pain but easier I think.
- robazMar 04, 2018Aspirant
Modem is modem only. Varies lan cables lead to access points in other rooms. Do you know if I can configure a VPM (exprees, astrill etc) directly onto the Orbi?
- FURRYe38Mar 04, 2018Guru - Experienced User
Some Orbis have there own VPN services. If you don't use it, I presume you can use exernal VPN routers behind the Orbi router. I would use the DMZ on the orbi router to help avoid connection issues with the VPN configuration. Having two routers on the same line causes a double NAT condition. DMZ can help here.
- robazMar 05, 2018Aspirant
Sorted it and very happy.
Turned off the wifi on the modem and switched the Orbi to AP mode. Flying!!!! and in China, up to 60mbps with a VPN on.
Thanks for your help
