joez
Jun 02, 2017Follower
Install Orbi with C6300
Hello,
I currently have a C6300 modem/router combo and just purchased the Orbi. I have the Orbi set to AP mode and the wireless radios are off on the C6300, and it appears to be working OK. Not the best performance though. Aside from turning off the wireless radios on the C6300, should I also set the router mode to No?
Thanks,
Joe
hi
you have 2 choices
bridge the c6300 and run the orbi in router mode
or
do as you have done and keep the c6300 in router mode with its wifi of and run the orbi in ap mode along with the sat
ether way works fine
what do you mean by not the best of performance ? your wifi should be much better now than it was with the c6300 and just its wifi coverage wise
1 Reply
hi
you have 2 choices
or
