gigberk's avatar
gigberk
install zipped downloads for orbi
What can I do to download and install the zipped software updates for orbi? They download but will not unzip! This is the most useless download system I've ever worked with. Help!
  • Ok. Glad you got it working. Please mark your thread as solved so other will know. Enjoy. :smileywink:
  • FURRYe38's avatar
    What browser are you using to download the .zip files? You do have to unpack the .zip files first before installing the .img files to the RBRs FW update web page manually.
    Try using IE11, Firefox or Opera to download the .zip files. The .zip files are working. Your browser or device maybe corrupting the files. I've downloaded them and many others have as well from this "system". The system IS working.
    • gigberk's avatar
      gigberk
      Hi Furry, thanks for the feedback. I'm using chrome on a windows pc. As noted, I can download the file but I cannot unzip it. I believe you that they work, I just want to know how. I've read all the info and how to manually do this and that, but they still would not open. Why should it take me forever to get this done.
      I'm comparing Netgear to my samsung phone. Updates to apps happen everyday and install without any issue. That's easy. This is not!
      • FURRYe38's avatar
        Try downloading using IE11, Edge or Firefox browsers. Chrome has been known to do things it shouldn't. Something else on your PC maybe corrupting the files once they are downloaded to your PC. Try a different PC.
        You can have Orbi update FW as well if you have it check for updates.
  • FURRYe38's avatar
    Any progress on this? :smileyindifferent:
    • gigberk's avatar
      gigberk
      Furry, I finally got the app to work. I removed it and re installed it on my phone. I did a full set up and the updates were then easily installed. There must have been an issue in my original app download but now it's working fine. Thanks for your help. Gig
      • FURRYe38's avatar
