trident
Sep 21, 2016Guide
Installation NETGEAR ORBI
Purchased an ORBI unit from Fry's today and just finished the install after 8 hours. Everything is as advertised, except setting up everything took some time; running wires, wire ties, syncing TV's,...
loomis1975
Sep 21, 2016Luminary
Glad it went well for you. I also am looking forward to adding a satellite to my setup.
- tridentSep 22, 2016Guide
The Orbi is a 10 plus system. It is great being able to use one wifi without having to reconnect all the time. In a 4600 sf house, only one area that is less than max. Will put in one sat later. Speedtest shows exactly same speed wired vs wifi. Well worth the price.
