trident
Sep 21, 2016Guide
Installation NETGEAR ORBI
Purchased an ORBI unit from Fry's today and just finished the install after 8 hours. Everything is as advertised, except setting up everything took some time; running wires, wire ties, syncing TV's,...
trident
Sep 26, 2016Guide
On day four with ORBI installed and everything is working exceptionally well. The Router is located in an upstairs closet along with a 3 X 8 electronics cabinet built into the wall. Prior to ORBI, I had 3 extenders and multiply connections through the extenders and very weak signal. With the ORBI I have everything going and full bars on 99% of everything hooked up. Installation was flawless and the only time required was checking every attached device to make sure of correct SSID and passwords. I have been looking for something like this since we built the house in 2002. Nothing has dropped or loss signal since hook up. We get 25/5 from our Internet provider and every room in the house when tested gets 25/5. Well worth the $400.00 price tag and will add a highly recommend for big house.
DarrenM
Sep 26, 2016Sr. NETGEAR Moderator
Hello trident
Thanks for the feedback on how its working glad to hear it is performing how you imaged it to.
DarrenM
