trident
Sep 21, 2016Guide
Installation NETGEAR ORBI
Purchased an ORBI unit from Fry's today and just finished the install after 8 hours. Everything is as advertised, except setting up everything took some time; running wires, wire ties, syncing TV's,...
dbgirl
Jan 13, 2017Aspirant
Hi there;
Loving the Orbi-we have 99% of our Spectrum Cable Internet in 3000 sq. ft house with 1 added satelite-everything that was on in the house(cable, TV's, phones) all synced nicely, took a bit of time but all went well. Problem is when i went to sync two more things later (another TV and Blu-Ray) they find the Orbi but cannot connect...made several attempts at syncing-any clues?
trident
Jan 14, 2017Guide
My knowledge is very limited, but I would try disconnecting everything and try a reset, then try pairingvthe two units that are the problem. If still will not connect then possible password or router settings. Sorry, but not that technical.
