Joewolf
Oct 18, 2018Aspirant
Installation Problem setting up Orbi with ATT DSL
I had my system working flawlessly, then changed internet providers. Now, my orbi system does not connect to the Internet, but if I plug an old nighthawk router in, it works fine. The old provider (t...
- Oct 19, 2018
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Joewolf
Oct 19, 2018Aspirant
I am on 2.2.1.210 for firmware. That said, I have no idea what daisy chain mode is, or how to enable/disable it.
my modem is from U-verse, it appears to be a Pace brand model 5268AC FXN. I don’t see any settings on it for bridge mode, and as I only have my tablet and phone, I am wary of disabling the radios as I would lose the ability to talk to it if the Orbi system still has issues.
Oct 19, 2018Guru - Experienced User
I would recommend contacting your ISP to help you with the modem. The problem is that your modem already has a built in router and wifi, and these are conflicting and interfering with the Orbi system. The 3 suggestions are options that you can have your ISP help you with to get the Orbi running thats best for yoru needs and gets the Orbi system connected well with the ISP modem.
You may need to barrow or have someone bring a laptop PC with ethernet support so while your working with the modem and Orbi system, you can get access to either over a wired connection should something happen.
