fljoemon
Feb 22, 2017Guide
Installing Orbi behind ATT Pace 5268AC gateway
Folks, Just got gigapower along with U-Verse TV and phone installed yesterday. While the Pace 5268AC is nice, it does not cover my entire house with WiFi, so I wanted to put a brand new Orbi behi...
fljoemon
Feb 22, 2017Guide
Thanks @TheEther for your reply ... I would keep everything same on the Pace gateway and will try changing the subnet on the Orbi router. My confusion is on when to do this. Should I do it after I set up DMZ+ on the Pace and reboot both the Pace & Orbi? Also to change the subnet on the Orbi, I am assuming that after I log in to the router using http://orbilogin.com, I go to ADVANCED -> Setup -> LAN Setup and in the LAN TCP/IP Box change the IP address to 192.168.2.1
TheEther
Feb 22, 2017Guru
fljoemon wrote:
thanks TheEther for your reply ... I would keep everything same on the Pace gateway and will try changing the subnet on the Orbi router. My confusion is on when to do this. Should I do it after I set up DMZ+ on the Pace and reboot both the Pace & Orbi?
You can do it before your connect the Orbi to the Pace.
Yes. Your connection to the Orbi will drop once you save this change. Force your device/computer to obtain a new IP address from the Orbi in the new subnet. Then connect the Orbi to the Pace and set up DMZ+.
- fljoemonFeb 22, 2017Guide
TheEther wrote: Yes. Your connection to the Orbi will drop once you save this change. Force your device/computer to obtain a new IP address from the Orbi in the new subnet. Then connect the Orbi to the Pace and set up DMZ+.
Sorry to be a pest here .. just want to make sure I am doing the right thing .. forcing my computer to obtain a new IP address is done by ipconfig/release and ipconfig/renew .. right?
Thanks!
- TheEtherFeb 22, 2017Guru
That'll work. If it's wired, you can simply unplug and replug the cable. If it's wireless, disconnect and reconnect.
