jcfax1
May 23, 2017Aspirant
installing orbi in a 4-story, 12,000 square foot house
For a 4-story, 12,000 square foot old house (lots of hidden metal), how many Orbi repeaters should I install? One per floor?
- May 31, 2017
Since Orbi is not currently a mesh network, be sure that the router (main unit) can be placed fairly centrally. Orbi is "hub and spoke". Also, when possible hard wire fixed devices to the router or satallites. Since you house is four stories you will need fewer satellites.
One advantage of Orbi is the ability to use fewer satellites in a large house due to the good range of these units.
jcfax1
May 24, 2017Aspirant
Thank you -- that makes sense.
Donnnn
May 31, 2017Aspirant
