pawan2003
Mar 24, 2020Initiate
Intermittent disconnection of wifi after upgrading firmware to 2.5.1.8
Hi All! Ever since I upgraded my firmware to version 2.5.18, my wifi seems to disconnect frequently. This is particularly felt while using apple products. Also, my phone and ipad tend to connect dir...
- Retired_MemberMar 24, 2020
pawan2003 wrote:Hi All!
Ever since I upgraded my firmware to version 2.5.18, my wifi seems to disconnect frequently. This is particularly felt while using apple products. Also, my phone and ipad tend to connect directly to the router instead of the satellite located close by.
2.5.18 has issues....get rid of it
Why did you upgrade?
Mar 24, 2020Guru - Experienced User
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m-p/1874136/highlight/true#M84647
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
factory resets are for loss password
