jedfsu's avatar
jedfsu
Tutor
May 17, 2022
internet disconnecting at least once daily x several months (2??)
We moved to a new home Dec 2021. Using existing Orbi products and switched from Verizon Fios to Xfinity [due to Fios not avail where we are].  I purchase a new Motorola Cable Model MB866 DOCSIS 3.1 Multi-Gig Cable Model.
We have an Orbi RBR50 basestation with 2 satellites.
At least once daily, maybe more, the entire system goes down. This started about 1 month ago.  There have been no changes.  The system comes back on w/o us doing anything.  Everything disconnects including my Avaya VPN phone which is plugged in the the Orbi basestation and my iMac, also plugged to Orbi.  There is a Belkin surge protector plugged into  a wall outlet and a few cord extenders as I can't fit everything into the outlet.
Xfinity came out and replaced a filter on the pole, tech said likely would not fix the problem and it did not.
Any suggestions? TY!!
  • plemans's avatar
    1. what firmware are you on?
    2. when it drops, does anything show in the router logs?
    3. have you noticed if the router reboots during this?
    • jedfsu's avatar
      jedfsu
      Tutor
      Well it seems that my Orbi firmware needs updating so am doing this now! Could this be IT?
      I think the Orbi turns purple? Not positive- I need to pay attention next time.
      And I’ve not checked router logs - not sure where to find this. I had gotten into the Orbi firmware at one point as my 2.4 network went down & I ended up paying netgear to fix as I did not have time. Some settings were incorrect.
      • plemans's avatar
        There was/is a couple of sketchy versions so it might help.
        I'd try that first.
        If it doesn't help, watch to see if its all devices or just devices connected to a satellite.
        You can also try swapping a power supply from one of the satellites to the router and see if its a power supply issue.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello jedfsu,
    I understand the Motorola model you have is a modem-only configuration. In that case, the solution above will not work.
    Are you able to connect a laptop or desktop computer to your modem to see if the connection is stable?
    Best,
    Kevin
    Community Team
    • jedfsu's avatar
      jedfsu
      Tutor
      yes I can connect my iMac. My Motorola seems very stable - when the orbi goes out for the brief time, all lights on my Motorola look stable
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello jedfsu,
        Thank you for providing that information.
        Best,
        Kevin
        Community Team
