krusch00's avatar
Dec 02, 2020
internet disconnects when plug in ethernet cord
i have internet on the device until i plug in an ethernet cord to go to my switch.. any ideas why?
  • Thats why I'm curious what the modem/gateway is.
    I've seen it but usually its a managed switch or double nat issue causing problems.
    For  every device to cause issues tends to confuse the issue a bit.
    How old is the orbi?
    If its within the 90 days free support window the client could contact support for free.
  • plemans's avatar
    1. What switch do you have?
    2. What firmware is on the orbi?
    3. What modem is the orbi connected to?
    4. What happens when you plug in the switch? Does the orbi reboot, do all devices drop (wired and wireless), does the connection not work? What exactly happens?
    5. does it only happen with the switch?  Plug in other devices and it works fine?
    • krusch00's avatar
      krusch00
      Guide
      its an hp switch 2810
      latest firmware on orbi
      it doesnt reboot or anything just looses internet
      its connected  to a fiber modem from the isp
      testing other devices now
      • plemans's avatar
        You need to be a bit more specific.
        the hp 2810 has several version. but they're a managed switch. Some managed switches have issues. Make sure to disable any green modes/features. Also disable igmp snooping on it.
        Which version of firmware? We ask because it changes frequently and a number helps those in the future with issues.
        What isp modem is it? Some have their own integrated router features.
