davraker's avatar
davraker
Follower
Jun 03, 2020
Internet freeze multiple times each hour for 10-30 seconds rbk50
I have an Orbi rbk50 and a Motorola MB8600. Mostly I have excellent speeds, but my WiFi freezes several times an hour for 10-30 seconds.  It reconnects on its own and works fine till the next freeze. I disabled the daisy chain hoping that would solve my issue, but no.  Then I turned off Armor and it seems to have solved the issue.  Have others had similar issues? Have folks had luck with Armor and the rbk50?  I like the idea of security, but the freezing issue was driving me crazy.
1 Reply
  • FURRYe38's avatar
