milobear19
Jan 28, 2019Aspirant
internet won't allow access to certain sites + fire stick apps/Apple TV apps
hi,
I have orbi set up and connected through our old internet modem (frontier) and I also have the orbi satellite- the connection is still not great (and we live in a two story condo) so the satellite is next to our rooms. When i go to watch tv on my apple tv i get- 401 Authorization
access to this resource is denied, your client has not supplied the correct authentication.
This also happens on our Amazon firestick, and certain websites i go on on safari (like today, a nail website)
And when i enter the serial number is disappears after a minute. I have reset modem multiple times.
How can i allow access to this all the time
thanks
- ekhalilMaster
What Frontier modem/router do you have? Is it the Arris NVG448x?
If yes, then it seems that you have double routers in your network: Orbi is a router and the ISP router is another.
You need to select one of those routers as your main router:
1. If you select Orbi as the router: then you need to set the Frontier router into bridged mode/passthrough mode or DMZ forwarding.
2. If you select Frontier router as the main router: then you need to set Orbi in AP Mode.
- milobear19Aspirant
- ekhalilMasterNot necessarily.
One quick way to test if you have double routers is to use traceroute.
Please open a Command Prompt on a computer connected -preferably wirelessly- to Orbi and type:
tracert 8.8.8.8
This will do traceroute to Google’s DNS server. If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good.
