rbussolotti's avatar
rbussolotti
Invalid IP - RBR20
Hi,
I was assigned a public IP address from my ISP and when configuring it to my router I keep receiving the Invalid IP message.
I checked it and I accurately made all the settings as indicated by my ISP. The IP class is xxx.yyy.zzz.kkk/31
My ISP says that the issue is on the router since they think it doesn't support the RFC 3021.
Can it be that a new router like the RBR20 with the latest firmware installed (V2.6.2.104) doesn't support the class /31 and RFC 3021?
Thank you
r
  • CrimpOn's avatar
    CrimpOn
    What subnet mask has been entered for this static IP address? (255.255.255.254)?
    Typically the gateway address is in the same subnet as the static IP address.
    A /31 IP address allows for only two hosts in the subnet. (device and gateway)..It had never occured to me to wonder how ISP's would assign static IP's.  This implies that for every static IP they assign, they burn another IP address from their pool for the gateway.
    Learn something every day.
    • rbussolotti's avatar
      rbussolotti
      Hi,
      Thanks for answering.
      Yes the settings are as follows:
      IP: xxx.yyy.zzz.67
      Subnet Mask: 255.255.255.254 (as foreseen in the point/point connections following RFC 3021 specificatiins - https://tools.ietf.org/html/rfc3021)
      Gateway: xxx.yyy.zzz.66
      DNS Primario: 8.8.8.8
      DNS Secondario: 1.1.1.1
      Any suggestion?
      Thank you
      • CrimpOn's avatar
        CrimpOn
        I am guessing that this Orbi is past the 90 days of "complimentary support"?
        It's ironic that the upper levels of ISP tech support almost certainly have direct links to the major modem and router manufacturers.
        Surely Netgear supports an RFC from 20 years ago.
        Reading the RFC, my first impression was that the IP's are "backward", i.e. the local host should be 66 and the network end 67.
        But, that defies common sense.  They provide static IP's all the time.
        When does the "Invalid IP" error message come up?  Does it provide any information besides "Invalid"?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi rbussolotti
    Welcome to NETGEAR Community!
    This is interesting. Please allow me to check this with the team and we'll get back to you.
    Blanca
    Community Team
      rbussolotti
      Hi Bianca,
      I was wondering if you heard any news from the team.
      Thanks a million
      r
