graysuit47
Jul 21, 2018Follower
IOrbi 15
Is it possible to have my RBR40 emulate my Verizon modem as an extention?
1 Reply
The RBR can only work as a router or in main AP mode. Can't extend any wireless as a client device.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
