dstranathan
Jun 02, 2018Apprentice
iOS devices appear as "Wired"?
Some of my iPhones and iPads (running iOS 11.4) incorrectly appear in the Orbi app and web admin console as "Wired"?
I have my Orbi satellites backhauled via Gigabit Ethernet to my Orbi router (all rooms were hard-wired with Cat5e runs in my new home at time of construction). But my ihones are not on the physical LAN - they are all using 5G Wi-Fi.
- RocketSquirrelLuminary
I see the same bug.
- budyLuminary
This happens, when you plug the LAN cable where the satellite is connected into the WAN port of the Orbi router. It will work, but the software get's confused, since this plug is only intended for the router, if your Orbi doesn't connect directly to your ISP and operates in AP mode.
Take a look at the manual about wiring satellites for wired backhaul and that issue should go away.
Nope. My Orbis are all correctly wired and I still see this. My Orbi “router” is in AP mode with its WAN port wired to my Asus router.
- budyLuminary
I haven't seen this since 2.1.2.18, when NG seemd to have fixed that issue.
I some cases, it may not be a bug. It's the system detecting which connection is being used when it comes to dedicated APs. When a AP device is LAN connected to the main router and a wireless device is connected this AP wirelessly, the router is detecting the wired connection since the AP has converted the wireless connection to a wired connection between the AP and router. Seen this before with other Mfr routers and AP when using LAN between AP and router. The detection will be seeing the wired connection and anything travelling thru it, even when wireless clients are connected to the AP. So in this case, it's working as designed...
