bsholbrook
Dec 16, 2016Apprentice
iOS devices
Running the Orbi formware 1.40.0.18 I've now experienced a couple of cases where an iOS device will infrequently get dropped off the network going from full signal to no wifi for upwards of 30 seconds...
genobkk
Dec 16, 2016Star
I have noticed a few dropout n iPad Pro and iPhone 7 plus, it drops for a second,iPhone goes to 4G then wifi comes back, my iPad is wifi only so I just see the signal drop completely then reconnects. This is not to often but it happens. An older iPhone 5s had the same issue. I have an Android box connect via LAN to satalite and no issues. Once again this issue does not happen often but I suspect it could be cause of a few VOIP calls drops whine useing Line2 on my iPhone 7 plus.
- bsholbrookDec 17, 2016Apprentice
i also have an ipad pro that is wifi only that dropped once yesterday. This ipad is running the latest 10.2 ios, so it is as up-to-date as possible.
Today I've not had any network issues ... crossing fingers.
- TomMacDec 18, 2016Guru
I downgraded to .16 and last night had no dropout on the Ipad. Wondering is it the older sw fixing or something else going on
